Hazard Lamp - Different Flashing Feequency
Just checking if this is the way the hazard lights work. When engine is on, they flash "regularly" at even intervals, like this: dit-dat-dit-dat-dit-dat. When engine is off, they flash faster at irregular intervals, like this: dit.dat---dit.dat---dit.dat. Got it? Is that how they work normally or is there something wrong? And why are they programmed to work like that?
our 99 ML320 does the same thing... I believe it is normal. BTW, I dont see how the voltage would vary with the engine off. 12 Volt battery is a 12 volt battery.
1) with the engine off, static battery voltage is actually higher than 12 V - usually 12.6 to 12.9 V in a fully charged battery;
2) with the engine (and alternator, of course) running, the voltage would be up to 14.4 V.
Conclusion: yes, there actually is a difference between the voltage with the engine on and off, which could explain the different cadence of the hazard signal.
I do not think that battery voltage has a direct influence on the flashing frequency for as long as it is above a certain value (e.g. 11,5 V). Maybe the flashing frequency does not change under a certain voltage but hazard light function just stops working? Mercedes says hazard lamp frequency should be 1,5 Hz (three times within two seconds).
