2007 e350 Replaced Blower resistor Fan keeps running Even with key out
I replaced the resistor for the ac/heater blower motor .. Because it was working sporaticaly .. after I changed it the and turned the key on it worked so I thought on High would not lower and then I turned off the key and it kept running i took the key out and kept running only way to stop it is to unplug the resistor .. I thought it was defective so I got another same thing happens.. If I put the old one back in .. it works .. when I say works I mean like before .. raises or lowers speed but then only when it wants to work does it come on.. Has anyone had any problems like this after putting in a new Resistor Thanks in advance..
Replaced it and now it does not run all the time worked for a few hours correctly but now its back to the usual state.. I guess its time to try the ac control..
