Hello everyone,
16 AMG GTS. I recently replaced the HVAC control module due to having zero climate control functionality “wont turn on, no lights on push button unit” and “no communication with AC control module“ when scanned. Also had “malfunction” warning message in center gauge cluster and thought they were related. Now with the new HVAC control module, the climate control System turns on, I can control fan speed, air temp, diffuse location, etc. However, the air only blows a constant temp (no hot, no AC cold air) no matter the temp set. All codes cleared and still have “malfunction” warning light on and scanner is showing no dtc’s. Any help is appreciated. Thank you.
John,
John,
member
pmercury
member
close
- Join DateOct 2016
iTrader Positive Feedback100
iTrader Feedback Score(2)
- Vehicle(s) I driveCL
Liked:807 Times in 622 Posts
you need to do a proper diagnostic with Xentry
shouldn't be a problem if you can afford a GT
I have icarsoft Mb 2. I do not have access to a Xentry system. Originally Posted by pmercury
you need to do a proper diagnostic with Xentryshouldn't be a problem if you can afford a GT
member
pmercury
member
close
- Join DateOct 2016
Quote:
look in you private messagesOriginally Posted by john5
John,
I cannot gain control of HVAC flap motors through scanner. The scanner is showing “NA” where you would normally enter a value to actuate the different HVAC location motors (floor, defrost, etc) Anyone have ideas what to check for now?Originally Posted by john5
Hello everyone,16 AMG GTS. I recently replaced the HVAC control module due to having zero climate control functionality “wont turn on, no lights on push button unit” and “no communication with AC control module“ when scanned. Also had “malfunction” warning message in center gauge cluster and thought they were related. Now with the new HVAC control module, the climate control System turns on, I can control fan speed, air temp, diffuse location, etc. However, the air only blows a constant temp (no hot, no AC cold air) no matter the temp set. All codes cleared and still have “malfunction” warning light on and scanner is showing no dtc’s. Any help is appreciated. Thank you.
John,
member
pmercury
member
close
- Join DateOct 2016
Quote:
probably just need a little online coding Originally Posted by john5
not possible with your "scanner" thing
