ML320 Engine problem...Please Help!
I noticed yesterday the engine was missing like a cylinder wasn't firing from the moment I started the car. It doesn't seem to make any difference what temp the car is running, it is consistenly missing even after it has reached running temp. The check engine light has never come on since this problem has occurred. I pulled all the ignition wires and tested them with a multimeter. All were between 2100 and 2300 except one which was only 8.9 so in other words basically a dead wire. Rather than messing with replacing only one wire I replaced the entire set with new wires. I am still having the same problem even with new wires. Took it over to a buddies house who is a mechanic (but not a Mercedes mechanic) who said he thought that a fuel injector may be clogged. I know Mercedes doesn't recommend using fuel injector cleaner but I dumped a bottle of Valvoline cleaner into the tank anyways to see if it helps out.
I drove through the McDonalds drive through today and since I was right up against the wall I could more easily hear the engine sound reflect back to the car. I could hear a fluttering sound come from the engine which definately is a wierd sound and overall it just has no power. Under heavy acceleration on the highway it almost sounds like a Chevy small block V-8 with a manifold leak or something. That's about the best description I can come up with as to how it sounds. I can smell gas fumes after I've parked it in the garage which isn't normal.
Any ideas? Thanks in advance!
John
Last edited by johng_22; Aug 10, 2004 at 10:11 PM. Reason: Edited with a more detailed description
