722.6 Transmission faults after fluid change
Old Aug 1, 2020 | 07:02 PM
breeze247's Avatar
W209 CLK55 - 2003
Car is a 2003 CLK55 with the 722.6 transmission.
I had performed a transmission service and the car was going into limp mode. I was left with the following errors showing on my iCarsoft i980:
  • Transmission Control Module, P240C The selector lever position sent from control unit N15/5 (electronic selector lever module control module) via CAN bus is implausible
  • Engine Control Modile, P2067 Fault is stored in component N15/3(ETC [EGS] control unit). (P0705)
Once reset, the above codes would re-appear straight away.
Edited to add a simple answer for the benefit of others: this was a gear selector fault. Replacement fitted and all is well.
