accessing washer fluid nozzle/hose in hood
C230K Sport Coupe /Black/C2/C7
I have a 2002 C230 Coupe, and the washer nozzle that sprays the windshield sprays only into the grating on the hood right before the nozzle. I'd like to check to see if the hose is broken or disconnected. The passenger side one still works fine.
I can't seem to get access to it. I've found three screws under the hood, but it still does not come out. What am I missing here?
any help would be appreciated.
austin-healy sprite,slk black
washers
hi, may i suggest you use a needle or pin and that may free out the tiny hole in the sprayer.if water is not leaking under the bonnet the hose is probably not disconnected
good luck
fab
good luck
fab
