When you hold down the rest button.........
S320L (W220)
When you hold down the rest button, you get a whole load of screens telling you about oil pressure, RPM etc. but does anyone have the full list of what each one is?
Car is 1999 S320L
Car is 1999 S320L
E550 Coupe
I got this from someone else in the W202 forum so im not sure if its the complete list for your car...
1. In-car termperature sensor (with aspirator blower)
2. Outside temperature sensor
3. Heater core temperature sensor
5. Evaporator temperature sensor
6. ECT sensor (Coolant temp.), e.g. 12*5 = 125C
7. Refrigerant pressure in bar, e.g. 12*8 = 12.8 bar
8. Blower control voltage, e.g. 16*5 = 1.65 volts
9. Software status of A/C pushbutton control module
15. Selected in-car temperature
20. Version code
21. Engine Speed (RPM), e.g. 6*0 = 600 rpm
22. Terminal 58d (Bat. Volt.), e.g. 99.0 = 99% of voltage
23. Vehicle speed (Kilometers Per Hour)
50. Not used – 00
51. Number of current slip recognition (poly-V-belt)
52. Number of stored slip recognitions (poly-V-belt)
20. Version code
50. Not used – 00
