Need help...
Old Jan 8, 2021 | 01:15 PM
Edgar Hdz11's Avatar
c250
Need help...
How’s it going recently ran into this problem. Check engine light/ no heat. P0597 code
its starting to get cold and been running the seat warmer since the heater doesn’t work.
any ideas?
Old Jan 11, 2021 | 01:27 AM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Replace your thermostat assembly. Mercedes benz thermostats fail in the open position causing the engine not to reach desired temperature. After replacement make sure your bleed it properly.
Old Jan 11, 2021 | 11:54 AM
c250
Awesome thanks, would that also cause p2681? Or is that separate
