Oil line routing diagram
Old Jan 22, 2021 | 01:02 PM
David Brock's Avatar
2003 cl55
Today i had an unavoidable accident on my way to work, I ran over a paint can and oncoming traffic made it unavoidable. After arriving i inspected closer and noticed a secere oil leak. Im assuming its an oil line due to not having a reading on the dipstick. I poured one gallon in and started it to find the source. What i discovered was that it was pouring through the power steering pump. Can anyone whose had that area disassembled shed light on what hose it may be? I want to add also,that it caused the red abc light to come on and the power steering seems nonexistant. Both resevoirs are still full of pentosin. I apologize if this is in the wrong area of the forum,it seems like a technical problem.
Old Jan 23, 2021 | 10:13 PM
chassis's Avatar
2017 GLE350 4MATIC
@David Brock Sorry to hear. You will need to do the investigative work to find the broken part, then order a new one(s) and replace it(them). Then fill, bleed and test the system. A suggestion is to post the question in the CL55 section where other others can make more suggestions.
Old Jan 23, 2021 | 11:20 PM
2003 cl55
Thanks guys. The wis should help immensely.
