W204 C180 estate starting problem
2011 c180 estate
Hi All
I am new here. I have a 2011 C180 Estate. I have problems with starting my car. At first it started almost immediately. Then it started to crank a little bit before starting. The problem is getting worse now it will take about 3-5 cranks before starting. I am worried that this could cause damage somewhere else if i continue cranking it this much everytime i start. I have replaced the crankshaft position sensor as well as the spark plugs but still same problem. I have checked that the ignition coil packs work properly. All checks out. Could it be the starter or maybe fuel supply problems? Please help. Any suggestions would be much appreciated.
