2009 R350 4matic, only one out of 3 cam adjuster marks out of alignment.
Today I pulled all 4 cam sensors to check alignment. Only 1 of them is off from center when the engine is rotated to 305 degrees.
Did only one sprocket skip a tooth? The pic was hard to take so even though the good three may not look perfectly aligned, they are. It's just the angle.
How can I fix this? Can I get slack in the chain and rotate that one sprocket back over a tooth?
What was likely to cause this? Tensioner? Secondary tensioner? Sprocket teeth look great from what I can see through the oil filler cap.
The attached pic shows bank 1 on left, bank 2 on right. Just like you were looking at the front of the motor.
