Cant get my WIS working
WIS gone
I can't either. It seems like Mercedes changed their internal software to no longer accept their old passwords. I believe that I can, however, get you to EPC. This file is not showing on your photo even after you have correctly logged in. Let me know if you need the supporting
data chain to replace on your software which is an easy fix. I wish that I could give you the WIS info but....only the EPC.
1995 S280 5-speed
I need WIS for my newly acquired 07 S550. Might as well get a much newer version like this for $20 https://www.ebay.com/itm/383671929971? I also see Xentry with laptop for $300 that includes WIS: https://www.ebay.com/itm/175871207217 Do you need an interface to connect it to the car with that?
1995 S280 5-speed
I don't know. If you can install and run VMware on an external drive, then it should work. WIS, in this case, is just an app that runs under VMware.
