Fault Code UO423
1 Post
W166 ML250 AMG Bluetec
Fault Code UO423
Hello Folks just a recap been having trouble for sometime regarding the above mentioned fault code,aprox 6 months ago the icarsoft kept coming up with supercharger/turbo charger inop and it was, eventually removed Turbo Actuator, only stripped and cleaned as all fuse links were in tact and the only thing i could see was the circuit board where the wheel comes in contact with the board was contaminated with something ? could only be grease from the gear wheels i guess,cleaned with Contact Cleaner and reassembled
OK ran fine for aprox 8. weeks or more no trouble from actuator / tubo working fine but still getting UO423 fault code,and again it was taking out the Actuator,so i remember reading a Thread about a Sprinter fellow member stating he had replaced is Outside ambient tempeture sender so today i also done the same ?
And all is well,but i have driven this carfor 7. Years with this Sender stating the Tempeture was of +85 degrees
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Received 1,634 Likes
Sorry, but I have no idea what you are asking.
1 Post
Hi thanks for the reply,what i was getting at, was the fact that the faulty ambient airr tempeture unit had been in the car for 7.years and only now is it causing a problem with the system,so i am not to sure of believing the Software ?
