oil leak on S600
2001 CL600
oil leak on S600
I own a 1995 S600 coupe. It has a pretty bad oil leak and I was wondering where should I start looking first. It has 114000 miles on it. The oil does not appear to be coming from the front of the engine. I would appreciate any hint on where to begin looking. The leak seems to be worse when the car is running.
Oil Leak
I have to say that engine.....its a monster.......lol. You really need to find someone who can place the car on a lift and raise it. Once you have it raised their will be a bottom cover that will be remove. At this point you will have a pretty close view of the bottom half of your engine. Are you postive it's oil your seeing. Some commom leaks on those cars can be Power steering and Transmission leaks. A trained mechanic will spot the leak for you.
