Engine code spec decoder
Old Dec 2, 2024 | 05:33 PM
porac's Avatar
Hi All,
Can someone point me in the direction of an engine number decoder or help me decode one please?
I need to get my engine replaced 651.950 xxx xxx xx and the mechanic is proposing a replacement with a 651.955 yyy yyy yy
I am concerned that the replacement may not be as powerful as the original I had so I wanted some help in decoding the 14 digit engine codes please. I want to make sure the HP and KW etc are of similar values by using the full engine codes/serials and not the VIN numbers.
Thanks!
JW
Old Dec 2, 2024 | 08:52 PM
JettaRed's Avatar
Veteran: Army
Did you ask the mechanic? Is this a dealer or an independent?
Old Dec 3, 2024 | 05:12 AM
porac's Avatar
I did ask and was told it's the same just different top level models. It's an independent mechanic this time. I was hoping through the engine number I could work out the spec of the engines but I've been struggling to find that.
Old Dec 3, 2024 | 06:33 AM
trigital's Avatar
W213 All-terrain
651.950 can be seen on V447 4Matic and 651.955 on W906 also with different power range.
