W210 heating problem
Old Feb 9, 2025 | 03:18 PM
Bobi_e430's Avatar
Mercedes w210 E430
I have the following problem with the heating system of my Mercedes w210. When I put it in the blowing position, it blows only to the driver and passenger, but not to the central one. What could be the reason?
Old Feb 9, 2025 | 03:44 PM
Chevota's Avatar
E550 Coupe 2wd (2016)
I'd say one of you little flap doors isn't moving. Try cycling it over and over between defrost and vent to see if you break it free. If not, it may need a physical bump, or smack. Or it may simply be broken.
I can't help you with where the vent door is, but I'm sure you can poke around and find it.
Old Feb 11, 2025 | 02:08 AM
Bobi_e430's Avatar
Mercedes w210 E430
Where the vent door?
Old Feb 11, 2025 | 08:45 AM
Chevota's Avatar
Basically in the ducting somewhere between the vent and air filter. You might be able find a picture of the ducting somewhere, or maybe someone here has it. I spose if you have a borescope you could stick it in the vent for a look-c
