ABC Drive Carefully warning
Old Nov 16, 2025 | 12:17 PM
K McCarthy's Avatar
2002 CLK 430, 2005 CL600, 2009 Smart Fortwo
Hi, I have a 2005 CL600 and lately have seen an issue. Twice now when the car is cold within the 1st few mins. of driving I have gotten the red ABC Drive Carefully warning. The 1st time I drove about .5 mile and shut off. I came back later that day and started and drove fine with no message. This morning the car had been parked outside in 45 degree weather and I drove about 1 mile and the warning came back. I parked and had my wife bring Xentry. I connected and watched the pressure. Upon startup it was 17 bar, I revved to 1500 rpm and pressure increased above 100. I then thought it was safe to drive home, it read between 189 and 191 the whole way home. The red warning stayed on the whole time but I could see the pressure was good. The issue seems to be related to a cold start. Does anyone have advice? Thanks!
Old Nov 16, 2025 | 12:21 PM
C280 Sport's Avatar
MB’s of all kinds.
It would appear the pressure in the system is low. I never had a ABC issue with my CL600 but it did the exact same thing as you once. I restarted the car and it never happened again. How is the fluid level?
Old Nov 16, 2025 | 01:40 PM
K McCarthy's Avatar
The fluid level is good, however it looked a little foamy on the dipstick. Maybe it's always like that but i didn't notice.
Old Nov 16, 2025 | 03:18 PM
Alexie's Avatar
A failing ABC pump causes this. Cold, thick fluid leaks past worn seals, dropping pressure and triggering the warning.
The warning stays on until reset, even after pressure recovers. You need a new pump soon. Driving it this way risks damaging other very expensive ABC components.
Old Nov 16, 2025 | 05:23 PM
K McCarthy's Avatar
Definitely not what I wanted to hear. I had the original pump rebuilt by RockAuto about 5 years ago. I probably have only driven 20,000 miles since then.
