New to the Forum/ Kilma & OVP RELAY
Subscribe
Jan 20, 2005 | 08:00 PM
Good afternoon, I hope someone can help me. I have a 1996 E320 which several items stop working. Can anyone tell me if this vehicle has a Over Voltage Telay and a Kilma Relay?
If it does can you describe the location?
Thanks in advance
Norman
Reply 0
Jan 20, 2005 | 08:21 PM
Neither. It does have a base module which is similar to the OVP. Can we get a better discription of your vehicle's problem?
Reply 0
Jan 21, 2005 | 09:20 PM
Thanks for your reply,
The vehicle's A/C, Speedometer, and cruise control + the check engine light + Check Engine electronics message came on all at once, also retreived all codes P1335, P0505 (Idle Speed Control), and P0134 (O2 sensor), but the vehicle's engine ran perfectly.
So I took the Vehicle to the dealer, and their estimate was for $2,800 the fix the following Items:
Replave broken A/C hose.
A/C dryer.
Replace instrument cluster.
Replace Alternator.
Replace Battery
Engine belt.
Ofcourse I did not leave the vehicle at the dealer for them to repair it. As it turns out and after 4 weeks of research and testing electric components, I decided an hour ago to remove the instrument cluster due to the tachometer was not working and to my surprise once I disconected the Cluster from the vehicle(1996 E320) the A/C started working perfectly.
It seems that the A/C module uses the tachometer as a reference so it knows that the engine is running, like the KILMA relay. I would not be surprised if the rest of the problems and codes go away after I have the instrument cluster repaired.
Perhaps someone out there needs this information. Pass it along
Where is this base module that you are refering to??
Thanks in advance
Norman
Reply 0
Jan 21, 2005 | 09:24 PM
Problem Solved, Not Ovp Or Kilma. Good Info
A/C dryer.
Replace Alternator.
Replace Battery
Engine belt.
Thanks in advance
Norman
Reply 0
Feb 20, 2005 | 09:36 PM
Instrument cluster
It seems that everything on the SL320 is tied into the instrument cluster.If I had to do it all over again I would have sent in my cluster for repair before I did anything else.I have had a number of people tell me to send it to Beckmann Technologies in Durham, NC.They will repair your SL cluster for $599.A new one for the 1995 SL320 goes for $1080 at the dealer and $850 for a rebuilt one at the dealer.So $599 seems to be reasonable.
Reply 0
Subscribe
Currently Active Users (1)
