2006 MERCEDES-BENZ R500super clean miles 23650
Old Jul 30, 2012 | 05:03 AM
hollywoodr500's Avatar
mercedes r500
miles 23650
858 212 5103
$24500.00 obo
NON-SMOKER
ONE OWNER
no accidents.
Premium Options
harman/kardon Logic7 system
rear audio controls
glove box mounted 6-disc CD changer
panoramic roof
rear pop-out windows
dual sun visors
pwr lift gate
DVD navigation
Tele-Aid
2nd Row Center Console
Heated Front Seats
Mechanical
5.0L SOHC SMPI V8 engine
7-speed automatic drive-adaptive transmission-inc: Touch Shift, optimum gear programming, direct select
4-wheel electronic traction system (4-ETS+)
Permanent 4-wheel drive
Electronic stability program (ESP)
Independent double wishbone high-strength aluminum-alloy upper arms & cast iron lower arms front suspension-inc: coil springs over gas-pressurized monotube shock absorbers
Independent 4-arm multilink high-strength aluminum-alloy upper arms rear suspension-inc: anti-squat geometry, alignment control, air suspension w/automatic level control
Front/rear stabilizer bar
255/55HR18 all-season performance tires
18" x 8.0" (5) twin-spoke aluminum wheels
Pwr rack & pinion steering w/integrated hydraulic damper
Pwr internally ventilated disc brakes
4-channel anti-lock braking system w/brake assist
Electronic brake force distribution
21.1 gallon fuel tank
Dual chrome exhaust tips
Exterior
Color-keyed bumpers
Chrome-trimmed color-keyed bodyside moldings
Silver painted grille w/chrome ribs
Variable-focus halogen headlamps w/high-impact polycarbonate lenses, driver- selectable light-sensing headlamps, automatic lamp substitution
Single red rear foglamp
Driver-programmable daytime running lamps w/auto-on
Dual automatically heated pwr mirrors w/integrated turn signals
Privacy glass-inc: rear door, rear quarter, tailgate
Dual aero-blade infrared rain-sensing windshield wipers
Intermittent rear wiper w/washer
Pwr assisted tailgate closing
Chrome-trimmed color-keyed door handles
Interior
8-way pwr heated front seats w/adjustable headrests, drivers adjustable lumbar
M-B Tex upholstery w/leather front seat inserts
Center console-inc: enclosed storage, dual cupholders, padded armrest, (2) rear 12V pwr outlets, rear air vents
Velour carpeting/floor mats
Stainless-steel door sill trim
Polished burl walnut wood trim
Leather-wrapped steering wheel w/pwr adjustable column, audio/multifunction controls
Multifunction display in instrument cluster-inc: trip computer, exterior temp gauge, oil level check, digital speedometer, audio status, compass heading, reminder/malfunction messages, driver-programmable settings
Touch turn signals (flashes (3) times w/1-touch)
Instrumentation-inc: tachometer, digital odometer/gear selection, fuel gauge, quartz clock
Mercedes-Benz Maintenance System Plus display-inc: distance remaining to next maintenance, type of service due, reminders
Messages & audible reminders-inc: open door, exterior lamp failure, low fuel, engine oil, coolant & washer fluid, release parking brake, headlamps-on, remove key from ignition
Pwr windows w/1-touch express up/down feature
SmartKey system-inc: remote central locking system, anti-theft engine immobilizer, drive away automatic locking
SmartKey infrared-remote-inc: opening tailgate, opening/closing windows, panic alarm, fuel filler door, lock/unlock all doors or drivers
Cruise control
Integrated 3-button HomeLink compatible garage door opener
Automatic anti-theft alarm system w/towaway protection
Tele Aid global positioning system (GPS) satellite system-inc: stolen vehicle recovery, remote door unlock service, automatic alarm/collision notification, (1) year subscription
Dual-zone automatic climate control-inc: electrostatic dust/pollen filter, tunnel mode w/(1) touch closing of all windows, rear air vents w/controls
Rear window defroster w/auto-shutoff based on time/exterior temp
COMAND cockpit management/data system-inc: AM/FM & weatherband radio, CD-player, large color LCD screen, (10) soft keys
(8) speaker audio system w/automatic speed-sensitive volume adjustment
Fiber-optic communication among components
Illuminated glovebox w/auxiliary input jack for MP3 player
12-volt pwr outlets located in ashtray & below glovebox
Dual illuminated visor vanity mirrors
Net pockets on front seatbacks & front RH footwell
Lighting-inc: programmable delayed-fadeout courtesy lamps, (6) reading lamps, illuminated cargo area, entrance lamps for all doors, front footwell lighting, night security illumination, locator lighting
Carpeted cargo area-inc: floor mounted tie-down hooks, 12V pwr outlet
EPA Fuel Economy & Specification
City 13/hwy 18 (5.0L engine/7-speed auto trans)
Vehicle Name : Mercedes-Benz R-Class
Body Style : 4 Door Wagon
Drivetrain : 4-Wheel Drive
EPA Classification : Large Station Wagon
Passenger Capacity : 6
Passenger Volume (ft3) : 148
Base Curb Weight (lbs) : 4917
EPA Fuel Economy Est - City (MPG) : 13
EPA Fuel Economy Est - Hwy (MPG) : 18
Wt Distributing Hitch - Max Trailer Wt. (lbs)
Wt Distributing Hitch - Max Tongue Wt. (lbs)
Engine Order Code
Engine Type : Gas V8
Displacement : 5.0L/303
Fuel System : SFI
SAE Net Horsepower @ RPM : 302 @ 5600
SAE Net Torque @ RPM : 339 @ 2700-4750
Trans Order Code
Trans Type : 7
Trans Description Cont. : Automatic
Trans Description Cont. Again
First Gear Ratio (:1) : 4.38
Second Gear Ratio (:1) : 2.86
Third Gear Ratio (:1) : 1.92
Fourth Gear Ratio (:1) : 1.37
Fifth Gear Ratio (:1) : 1.00
Sixth Gear Ratio (:1) : 0.82
Reverse Ratio (:1) : 3.42 (Comfort Mode 2.23)
Clutch Size (in)
Final Drive Axle Ratio (:1) : 3.70
Suspension Type - Front : Independent
Suspension Type - Rear : Independent
Suspension Type - Front (Cont.) : w/Coil Springs
Suspension Type - Rear (Cont.) : w/Coil Springs
Front Tire Order Code
Rear Tire Order Code
Spare Tire Order Code
Front Tire Size : 255/55HR18
Rear Tire Size : 255/55HR18
Front Wheel Size (in) : 18 x 8.0
Rear Wheel Size (in) : 18 x 8.0
Front Wheel Material : Aluminum
Rear Wheel Material : Aluminum
Steering Type : Pwr rack & pinion
Lock to Lock Turns (Steering) : 3.62
Turning Diameter - Curb to Curb (ft) : 40.7
Brake Type : Power
Brake ABS System : 4-Wheel
Disc - Front : Yes
Disc - Rear : Yes
Front Brake Rotor Diam x Thickness (in) : 13.8 x 1.3
Rear Brake Rotor Diam x Thickness (in) : 13.0 x 0.9
Drum - Rear : No
Rear Drum Diam x Width (in)
Fuel Tank Capacity, Approx (gal) : 21.1
Front Head Room (in) : 39.8
Front Leg Room (in) : 39.8
Front Shoulder Room (in) : 60.3
Second Head Room (in) : 40.4
Second Leg Room (in) : 36.2
Second Shoulder Room (in) : 59.6
Third Head Room (in) : 37.2
Third Leg Room (in) : 32.4
Third Shoulder Room (in) : 52.8
Wheelbase (in) : 126.6
Length, Overall (in) : 203.0
Width, Max w/o mirrors (in) : 75.7
Height, Overall (in) : 65.4
Track Width, Front (in) : 65.5
Track Width, Rear (in) : 65.3
Min Ground Clearance (in) : 5.8
Cargo Area Length @ Floor to Seat 1 (in) : 92
Cargo Area Length @ Floor to Seat 2 (in) : 43.0
Cargo Area Length @ Floor to Seat 3 (in) : 19.4
Cargo Volume to Seat 1 (ft3) : 85.0
Cargo Volume to Seat 2 (ft3) : 42.2
Cargo Volume to Seat 3 (ft3) : 15.3
Seventh Gear Ratio (:1) : 0.73
Safety
Driver/front passenger adaptive dual-stage airbags w/front passenger occupant classification system
Driver/front passenger side-impact airbags
Side-impact air curtains
3-point height adjustable driver/front passenger seat belts w/adaptive force limiter/emergency tensioning device
3-point 2nd row seat belts w/force limiter/emergency tensioning device
Universal LATCH (lower anchors & tethers for children) system for 2nd/3rd rows
Attached Thumbnails 2006 MERCEDES-BENZ R500super clean miles 23650-imag0284.jpg   2006 MERCEDES-BENZ R500super clean miles 23650-imag0311.jpg   2006 MERCEDES-BENZ R500super clean miles 23650-imag0312.jpg
Old Jul 31, 2012 | 09:05 PM
arejohn's Avatar
Crossfire Roadster
Looks like the car I am trying to find. But it looks like your in SD and I am in NC.
