93' 300CE
As I hate to do this, I am placing my 93' 300 CE up for sale. I have a new grandson and will need a car that I can put a car seat in the back, (read 4 door)
I have owned this car for 5 years and have really enjoyed it. The car currently has 202,000 miles which will increase as I am still driving the car some. The car has a clean Carfax that I can provide with no accident history. Over the last year I have done the following maintenance:
New shocks/struts (HD Bilstine)
Strut mounts
Rear caliper and pads
Center support bearing
Front and rear flex disk
Alternator
Wiper Motor
Fuel lines to injectors
Power steering filter
Transmission filter and fluid
Tires (less than 4,000 miles) Goodyear Eagles
I had a compression ring brake on number 3 cylinder, so I had all new bearing, rings, chain guides, timing chain, valve stem seals, thermostat and spark plugs installed. The engine runs GREAT!
Everything works with the exception of the Gas gauge (I have a replacement instrument panel with working gauge) it is the gauge not the sender that has failed. The oil level sender is flakey and come on at times although the oil level is fine. AC is cold and HAVC works as it should.
The paint is good but it does have a few rock chips on the front and on the hood.
The interior is very good with only minimal ware on the drivers side seat, Carpet is clean with no stains.
I am looking for $5,500 And the car is located just north of Charlotte,NC
