It is time to move on. I found a CLK55 that I would like to snap up. If you do some searching you will find that I have had some problems with the car but, I have worked out a bunch of them. PO replaced the motor with a slk32 motor. I dont have proof anymore (he texted me pics and i dunked my phone) but motor has bout 70k on it. Runs like a stuck pig.
The good:
18" Renntech Monolite wheels with nearly new Bridgestone ps04 tires
65mm supercharger pulley
Bi-Xenon headlights
New motor mounts (OE)
New transmission mounts (OE)
New conductor plate and PWM solenoid (OE)
Transmission fluid replaced at the same time with MB brand fluid
New water pump (OE)
Replaced alternator (rebuilt)
Tien coil over suspension
newish pulley saver / belt wrap kit (Needs wings)
New Battery (OE)
Alpine head unit with GPS DVD and 10 disc CD changer
New AC condenser and dryer (OE)
newish Johnson SC pump
Clean Tile in hand
The bad:
220k miles
Hood struts are shot
drivers heated seat does not work
Needs passenger door seal
no spare tire. I will throw in a can o fix a flat though
Needs flap actuators for the AC
leaking at the PS reservoir
also needs new rear axle boots
I replaced the washer fluid pump but the o ring leaks
6k takes it
I think this is a fare price but don't be sacred to shoot me an offer. I can text more pictures if your interested.
The good:
Bi-Xenon headlights
New water pump (OE)
New Battery (OE)
Clean Tile in hand
The bad:
220k miles
6k takes it
Price Drop. 5k The wheels are worth 2k
last call at 4k or its getting traded in this weekend
car is sold.
