92 500e 74k miles
Old Dec 29, 2016 | 12:36 PM
glasig's Avatar
92 500e
92 500e 74k miles
This 500e is a two-owner example that is completely stock and drives and performs as new, even smells new. Clean CarFax. All equipment functions as designed. I even sent the original Becker radio off to be repaired and now works perfect. . No rust can be identified anywhere, including in the vulnerable battery/trunk area. The interior is nearly perfect with a new OE headliner. All leather surfaces are as new and very soft . Most importantly, all of the following has been completed within last 1000 miles and costing nearly $10k.
BFG sport comp 2 tires and spare, rotors and pads, stainless brake lines and new fluid, trans mount, trans cooler hose, trans flush and filter, front and rear flex disc, driveshaft center bearing and carrier, differential flush, upper and lower temp sensors, cabin filter, Front lower control arm bushings, rear SLS flush, ignition distributor caps and rotors, spark plugs, new belt, radiator, thermostat, coolant flush, fuel filter, new headliner, headlight switch, fog light lenses, windshield fluid reservoir, rebuild factory radio and more....
asking $34000 contact Jordan 863.224. seven two zzero zero
https://flic.kr/p/MJCBRD
Old Dec 29, 2016 | 09:32 PM
tink and tonk's Avatar
MOST OF THEM
Mate, you might want to check your link.
I'm interested. Please email: properhistorics@gmail.com
Old Dec 29, 2016 | 10:12 PM
tlambert's Avatar
2005 E55 AMG
Beautiful clean car!
