ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
$1,300 for a headlamp?!?!?!?
Old Jun 30, 2005 | 05:50 PM
Bulldog55's Avatar
2002 ML55
Hi Folks,
Need to pick your brains for a moment.
Does anyone know if the 7mm nylon (plastic) hex adjusters used in aiming the bi-xenon headlamp is a piece that can be purchased separately? MB parts counter wants to sell me the whole housing ($1,300) instead of the single part (likely to be about $0.50) . Gimme a break!
The precise piece I'm looking for is an offwhite nylon (plastic) material that you actually put your hex wrench into which adjusts the lamps up and down direction. The one I'm looking for is on the drivers side (although all 4 are likely to be the same) just above the low beam on a 2002 ML55.
