ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Bigger is better
Old Oct 20, 2006 | 09:08 AM
MSDLTD's Avatar
ML63
Bigger is better
Can a 300 or 305 tire fit on the rear wheel?
BOSS man, It has some butch look in the rear.
Old Oct 20, 2006 | 10:50 AM
EX-BEEMER's Avatar
'08 SL550 Sport, '11 BMW 550ix M sport
Why the staggered wheels? The dry traction with the AWD is already awesome. Man! at 305's on the rears the footprint would be massive!
Who is BOSS man?
Old Oct 20, 2006 | 02:28 PM
MSDLTD's Avatar
ML63
Who is BOSS man?
We are talking Hot Rod Material here.Wheels no, just slightly wider tires in rear...usually the wheel allows 1 size larger tire without consequence...
I think the look from the rear would be even more " KILLER"
Old Oct 20, 2006 | 04:43 PM
PhilS's Avatar
SL500 /Porsche 997S/Porsche Cayenne Turbo
The respective widths are:
295 - 11.61 inches
300 - 11.81 inches = + .2 inch
305 - 12.00 inches = + .39 inch
I don't know if you can put a 305 tire on the existing 10.0J X 20" wheel. It might require a wider wheel.
Phil
Old Oct 23, 2006 | 08:42 AM
MSDLTD's Avatar
ML63
295 - 11.61 inches
Phil
How does that effect the Height of the Tire...same series.
Dont want to tick off the DSC
Old Oct 23, 2006 | 02:48 PM
PhilS's Avatar
How does that effct the Height of the Tire...same series.
You can check most tire sizes here: http://www.americanracing.com/techce...Calculator.htm
Comparing a 295/40 with a 305/40:
295/40
Tire diameter: 29.291"
Tire width: 11.614"
Tire sidewall: 4.6456"
305/40
Tire diameter: 29.606"
Tire width: 12.007
Tire sidewall: 4.8031"
Phil
