ML 63 - A Workhorse
I did get the 19's and premium, however the car is being gutted and setup for the track. Already replaced the 19's with 18's and stickies, short shifter, race exhaust, air intake, front CF splitter, rear CF diffuser, waiting for a new static brake setup, CF Trunk with race wing, 5-point harness on the way, seats to be replaced, etc, etc..
Impressive mod list on that M of yours...big respect
And yes, it will look odd, in a good way I guess, pulling an M3 with an Ml63. The dealer is just jerking me around. Now I allegedly need a new brake control box, 500 bucks, to control the trailer I bought (featherlite 17'6) because it has electric brakes bringing the grand total to 2k.
I got some good props 4 years ago when I pulled into a track with my ML55, 2 ducati's on an open trailer....which isn't even on the same level you're going at.
Weighs about 7100 pounds before gear, about 8000 after.
Long story short, when the travel trailer store tried to wire up the gl450 with a brake control adjustment (to allow for adjustment of how hard the trailer brakes) they completely fried the entire electrical system.
The GL was towed to the MB shop, and I was left stranded with the trailerabout 250 miles from home.
I made a call to my wife who was driving the ML 63 at the time and she came to pick me up. I was going to leave the trailer there, but was a little mad at the guys and wanted to get my trailer home.
Being the daredevil I am, I hooked the trailer up to the ML63.
The ML performed PERFECT in every aspect.
It accelerated with ease (most of the time faster then the other cars on the road)
I tested the brakes a few times and the AMG brakes brought the whole rig to a stop FASTER then I ever expected. I used to own a truck, and it outbraked even a truck with a trailer.
On the road the ML was very stable once it was put in sport mode.
It got about 8.7 MPG, and might have gotten better but I left it in 4th gear to help.
I am actually considering using the ML instead of the GL to tow the trailer because it performed so great.
Just a little information for those owning and considering a ML 63. Enjoy.
Do you have trailer brakes/brake controller? That should help with the brake dust but you probably used to it since you own an M-car...
I've found the IBC on my super duty to work very well, been towing the triple axle fifth wheel and hardly know it's back there....can never have to much power towing and although your mpg isn't good I bet that 6.2 will deliver all the mph you want...
So far so good. Yes, Electric brake controller. I went with the SAM from Mercedes. My only complaint is you can't adjust the pressure on the trailer.. We trailered to Englishtown and back on a 1/4 tank 90+ miles round trip at 75 MPH. For me thats DAMN good.
And BTW, I choose an 18' FT Steel, open center trailer, instead of the featherlite. A few reasons, the next logical step will be an enclosed trailer, the steel open deck is actually lighter, and it allows me to get under neath the car like my own personal lift. The cost difference was nominal. 800 bucks I think.
couple of questions for exbeemer and idangeli.
exbeemer looks like you're towing your boat with a weight distribution hitch. do you know if the ml is ok to use this type?
idangeli- with the m3 on the trailer and enough tongue weith does the ml63 level itself out?
I tow my e36 m3 with a ml350 (kinda the low end setup to ideangelli!) and have sagging of the rear springs with the proper tongue weight. couple weeks ago i was heading to watkins glen, it was raining that nite and visibility was terrble with headlites pointed to the sky. my solutions are a weight distribution hitch, if it's compatible with the ml- or- get a air suspensioned ml to try to get the truck leveled out. would appreciate any feedback.
thx!
If it makes you feel better, my ML55 does the same, sags like a... when i pull a boat that is
thx!
