Tires Quastion
Tires Quastion
What well be the maximum size of tires in 22”.I know that is recommended to have 295-30-22..Do you know if is possible to install larger tires like 295-35 or 295-40 ?
35 and 40 will be too much tire, and too different from factory requirements.
I questioned this too, but the 30s are not as bad as they sound
07 ML63 Silver Dead at 85k, 14 RS5, 05 SL600
Very much so. Thats why I stayed with the 20 inch rims. Apart from looking in proportion to the ML63 IMO they are much better for the roads I am often on. Even so I hit a very large pot hole at speed this winter and dented the stock AMG rim. There were cars pulled over after with blown tires. Good rims should bend and good tires shouldn't blow. Fortunately there is a local company that was able to repair it. They heat it, straighten, remachine and then re clearcoat/paint.
