ML55 problems-help!
2000-ML55-AMG
ML55 problems-help!
hi everybody,
i own a 2000 ml55 w/ apprx. 75000miles on it. i bought it about a year ago and i've been pretty happy with the car except a few problems. i had a problem with the windows (they won't go up or down) but that ended up not being a big deal (i had to change that thing that plugs in the fuze box for about $25)
another problem i have right now is with the transmision! i'd step on the gas and the car just won't go(sort of running out of gas) and the days when it's not that bad it drives fine for up to 25-30mph and then when i try to go faster it just would rev up and not change gears...i'm really worried about this problem, anybody knows what the problem might be? i forgot to add that i went -1000 miles without servicing it, could that be it? how much will it cost to fix it?
hi everybody,
You have the same symptons that my ML55 had that after I replaced the MAF sensor. It would idle fine. If you tried to accelerate, it acted like something was wrong with the transmission....the engine would rev but not upshift. Would not go faster than 40 mph. Do a search on this forum and see if others experienced the same problem.
2000-ML55-AMG
yes. i went to the mechanic and said i ll need a new air flow sensor. along with a tune up (3 cylinders misfiring) should fix the problem. thing is, he said it will cost 500 for the sensor and 500 for the tune up+trans service, and 250 to change front brakes.
comes to 1200-1400$
do these prices sound reasonable? i looked online for sensors and i see that they cost 100-250, am i getting ripped off??
comes to 1200-1400$
00' ML 55 AMG; 08' Jeep Wrangler Unlimted (4 Door)
comes to 1200-1400$
comes to 1200-1400$
Depends....
Do you know how to do any basic type of service on your vehicle?
You could do your own brakes pretty reasonably, and changing the MAF is pretty idiot proof.
Get another quote about the tune-up and Trans service. I got my tune up/60K service for about 300. I just did not have time, but it included all needed parts (filters, 16 Spark plugs, etc.)
