ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
ML63 AMG Engine Temperature
Old Feb 22, 2009 | 12:08 AM
wwml63's Avatar
2008 ML63 AMG
Does anyone know what is the acceptable engine temperature range for the ML63? In city driving, mine hovers between 100-105C which seems a bit high. thoughts?
Old Feb 22, 2009 | 03:53 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
That is a normal temperature. The 63 Engine has a variable thermostat so when you're sitting in traffic or it cold outside it puts the engine temp higher. When you give it some or it's hot outside then it trys to run a lower temperature. It's all for fuel efficency.
Also you may find your oil temps going upto 140C in hot weather, this is ok too. 100-125C oil temp is normal
Old Feb 22, 2009 | 10:52 AM
wwml63's Avatar
2008 ML63 AMG
Thanks for the info...
Old Feb 22, 2009 | 05:44 PM
Maverick1975's Avatar
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
Hey Ausmbtech, i sent you a private message, please have a look when you get the chance
