ENGINE SIEZED UP!!! $75,000 REPAIR
Imagine my surprise when they told me that the engine had totally siezed up! After a week or two of diagnosis they determined that a simple valve spring had broken allowing the valve to drop into the cylinder. From that point on the engine block was toast.
What shocked me the most was the fact that the replacement engine invoiced out from Mercedes at about $68,000 complete! $68,000!!!! That didn't include labor! Even though the ML is assembled in the states, the engine had to come from Affalterbach which took about another month.
Props to Vin Devers Mercedes and Mike for making the best out of a really bad situation. I picked up my ML last Friday and it's good as new although I have to go through the whole engine break in proceedure again.
A real P.I.T.A.....
My whole reason for the post is to warn everyone to strongly consider never owning one of these vehicles out of warranty. If I decide to keep my truck at lease end, I'll be sure to get an extended warranty from Mercedes for as long as I own it. I was told to make sure it was a Mercedes Extended warranty because many aftermarket warrantys don't cover AMG parts.
My service manager told me that if the spring would have broken while at highway speeds it could have been catastophic... not just the engine but transmission and other drivetrain components could have been trashed as well. The vehicle might have been totaled!
I have one of the first ML63's sold in the US and my engine was built by Tobias Schultz. As these vehicles age I hope this was just a fluke, but if your ML63 is about to run out of warranty, I'd really consider extending your warranty. Just think of it as Insurance.
I am just about out of warranty on my 07 and I will be checking into extended warranty.
There are many here that debate on this, and as pointed out most aftermarket warranties do not cover AMG parts, and for that matter some of the MB systems such as airmatic and others when the insurer finds out the price tag.
MB Extended are more expensive, but when it comes down to arguing about labor rates with an aftermarket warranty because they won't cover MB dealer rates it gets ugly.
Just a thought to add.
As for buying another ML63 for the cost of the repair... you're right! Prior to this event, if anyone would have asked me what I thought a 63 engine would cost I would have guessed around $25,000 to $30,000. Never in my wildest would I have guessed $68,000!
Since it was an engine failure , insurance really does not factor in. However had the OP crashed as a result of the engine failure, different ball game.
The OP is very very very very fortunate it was cut and dry. Warranty eats the 75k cost and the op essentially used the ML for 30k miles and get to start over . Nightmare, but definately a happy ending.
But good you had waranty...
Not true in most states. Many have a requirement that in order for anyone (including owner etc) to retain salvage (meaning you get back the totaled vehicle less (minus) the salvage value), it must be over a certain age. For example in IL it has to be over 9 years before you can keep a totaled vehicle (owner retained salvage). Other factoid: Where do you get the fact?? that insurers get 20% of the totaled vehicle back. Often it is way less than that??? So, on a $4000 car, they are getting back at least $800.00??? Often it can be only $300-$500 or less?
...you get back the totaled vehicle less (minus) the salvage value), it must be over a certain age. For example in IL it has to be over 9 years before you can keep a totaled vehicle... Where do you get the fact?? that insurers get 20% of the totaled vehicle back.
I'm a member in another forum, and I know somebody there who payd 27500€ for new engine for his CLK63, here in Germany at the Mercedes dealer..
It can't be that expensive in the U.S.
In that case it would be cheaper to ship the whole car to Germany and back.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
