ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Paddle Shift Conversion
Old Jan 3, 2011 | 07:37 PM
hercules's Avatar
W203 C200K-2003
Thanks schmick325,
Attached is a copy of the electrical wiring of the paddle switches and others ..that it might be of use to other members.
Now you mentioned above that I will not be able to shift gears unless I'm in motion, but with the actual steering wheel and paddles I can do that, I just went to check now to be certain and once I select D I can select gear from one to 7 in stand still !!
File Type: pdf
Old Jan 3, 2011 | 07:40 PM
schmick325's Avatar
RR Evoque Dynamic, Benz Valente (work hack)
Hmm, interesting.
What car do you have?
I can't remember if my car did that when I had the old rocker switches in.
Not really a big deal anyway
I doubt your car will drive off from a standstill in 6th or 7th!
Old Jan 3, 2011 | 07:52 PM
hercules's Avatar
W203 C200K-2003
Originally Posted by schmick325
Hmm, interesting.
W164 320 year 2006
No but it comes handy to start in second or third gear when you sit on ice
Old Jan 11, 2011 | 05:07 PM
hercules's Avatar
W203 C200K-2003
It is done , it realy was plug and play.
Old Jan 12, 2011 | 07:49 AM
schmick325's Avatar
Good to hear.
I drove a 2009 ML63 the other day (factory fitted paddles) and you could not change up gears with the car stationary.
Must be an AMG model thing
Old Jan 12, 2011 | 09:51 AM
hercules's Avatar
W203 C200K-2003
Possibly , all I can say that it is a sport edition and it has got all the posiible MB options except LINGUATRONIC, that is why I needed the new S.Wheel buttons.
Thanks for the help
Old Jun 1, 2011 | 10:43 AM
  #32
Pac55's Avatar
AMG GTS
hi there - any chance of emailing me the wiring for the amg paddles too please
arcwebmaster@optusnet.com.au
Pac Man
Old Apr 2, 2012 | 12:24 AM
  #33
Utahkompressor's Avatar
W124, W203, W204, W251
Just curious...what is this 2-pin for? There is nothing connected to it.
Old Jul 1, 2019 | 10:36 AM
  #34
Kevinlfifer's Avatar
s550, gl450
My 2007 ml350 gear change paddles don't work at all
The paddles do nothing. Is there a setting to activate? Could they be totally worn out? The ml350 has the sport package.
I'd like suggestions before I tear into it.
I did disconnect the battery for over an hour for a different issue, but no change.
There are no transmission codes when I connect my icarsoft 980.
