2000 ML55 Rear Suspension Help
I have been having some issues getting my suspension dialed in on my ML55. I bought it about 3 years ago, and I the previous owner had dropped springs on the rear (I guess). The shocks look like Bilsteins and have purple springs on them. I am not sure if this is the stock setup but I doubt it. To match the lowered height the guy just dropped all the tension out of the front torsion bars. Rode unbelievable rough, but handled like it was on flypaper.
I blew out 2 front shocks before I figured out what the guy had done. I have since raised it back up a little in the front. I would like to raise the whole truck up back to the stock height or to the ML 430 height. I am really having problems finding any suppliers for the rear spring/shock combination that does not drop the truck.
I am trying to get it more to a height that would be suitable for longer drives and light towing rather than track performance. I am finding the shocks for the 430, and 500
http://www.autopartswarehouse.com/de...e&apwidAXGczYD
But no-one is saying anything about ML 55. Even the dealer didnt show a part other than springs.
Question:
Has anyone else had this experience?
What shocks/springs did you replace with WITHOUT dropping the truck?
Can ML430 Shocks/Springs be used on the ML55?
Thanks!
Paul
Also, what is with the creaking and popping from the front torsion bar adjustment area. I had a local shop replace the nylon inserts and that seemed to work for a few hundred miles then it came back with a vengeance. I bought them off ebay from a seller that had then listed for a few models. I could not seem to find the OEM part number or listing for the factory inserts. Do I need to replace the whole torsion bar system?
Has anyone had experience with this issue?
Also note that the truck had over 110k on the odo before I replaced the shocks and springs, so I was already going bad.
