Throttle restrained below 4000rpm?
Subscribe
Jan 25, 2011 | 04:26 AM
Is it some built-in safe restraining?
Because when I hit 4000rpm it is like a flick of a switch and it realeases a lot of more hp by itself, without changing the pedal (floored).
Is this correct or is it some problem with the car?
Question 2:
Power steering is really heavy in slow speeds.
Oil and so is of course checked.
I even tried to override the plunger in the power steering by supplying 12V directly. And then it was easy to steer (at low speeds....).
I believe this is a common problem but do anyone know if it is easy to fix?
Reply 0
Mar 10, 2011 | 02:59 AM
Power steering and throttle.
Anyone?
Reply 0
Mar 18, 2011 | 01:42 PM
the 4000 rpm cut off is the rev limiter.
hard to steer is possible plunger valve or control unit. Mercedes had a bulletin to replace control unit so i would get a scan tool and check for fault codes in the traction computer.
Reply 0
Subscribe
Currently Active Users (1)
