ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
2000 Ml55 Heat Blowing, Won't adjust.
Old Nov 25, 2011 | 10:40 AM
chimchamp's Avatar
1995 c36
Thumbs down 2000 Ml55 Heat Blowing, Won't adjust.
ANy clues here? It just started (150k miles) I've had it for a week.... it worked somewhat normally, but was a little inaccurate when you adjusted temp.... now it's just full hot all the time, the dial won't mix in cool air.... it's a servo motor flap deal? Where is the item, how hard to swap, how much is the part?
Thanks,
Mason
P.s.
Full cold doesn't mix in cold air, so I assume it's not temp sensor related.
