ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
2007 mL 63 AMG Battery Light on
Old May 6, 2012 | 09:01 PM
Johnzaza's Avatar
ml 63amg
I am having a problem with the battery light coming on the truck.
The charging system is working fine, full charge.
Wondering if any Mercedes techs on the forum might know.
Old May 9, 2012 | 09:14 PM
Johnzaza's Avatar
ml 63amg
WOW 170 PEOPLE LOOKED AT THIS POST AND NO RESPONSES.
Old May 12, 2012 | 01:46 PM
ruleman's Avatar
1967 Pagoda 250 SL / 2009 ML 63 AMG
Sorry to say that all I can add to this thread is that I too am looking at the same issue on a 2009. I've checked out one of these for sale and the battery icon was showing up on the center of the instrument panel... Unfortunately the sales guy was less than knowledgeable and wasn't able to tell me exactly what that meant.
The MB owner's manual for the 09 only states that either the battery is no longer charging (Poly-V belt failure, alternator malfunction, electronic system malfunction), or that the battery is defective. However, I can definitely say the Poly-V belt is not torn, broken or damaged) but I cannot tell which of these other options would be the case simply by looking at the Icon on the message center display.
Johnzaza, you may want to go thru your manual to see if anything there helps you with your issue.
Anyone can shed some light for the fellow forum member and myself?
Thanks in advance,
Andres G
Old May 12, 2012 | 10:01 PM
B-tsai's Avatar
CLK320, ML550, SL55, GL450
There's 2 batteries. Did you check both?
See your user manual. I believe its under the passenger front seat.
Old May 13, 2012 | 04:43 AM
Maverick1975's Avatar
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
I can only suggest you take to dealership. They can clear fult code and might never see light again??
Old May 13, 2012 | 08:18 PM
B-tsai's Avatar
Did you find the other battery yet?
Read this: http://www.benzworld.org/forums/w164...t-options.html
Old May 16, 2012 | 11:24 PM
ruleman's Avatar
Thanks guys. The dealer where I plan on buying the car worked on the car and told me it was an auxiliary battery that needed replaced.
I am considering this car, but it has rough looking wheels (see other thread) and I am working to get to an agreement on final value considering the work it will take to get the rims back to nice looking condition.
Thanks again for the help with this.
