ML 500 Exhaust System Updates
Now when I removed the very restrictive OEM exh manifold every stud backed out with the loc-nut still on it. So I cleaned & tapped all the heads , wear the studs were , cleaned the studs. loc-tite them back in place with Green loctite . The OEM manifolds outlet is a small 42mm / 1-11/16ths". and the new Klee headers outlets are 59mm / 2-3/8ths" The headers went in with no fitment issues , The down pipes that were supplied fit well , just had to cut for lengthI then was off to the custom exh shop with the pipes and had adaptors to go from the down pipes to the smaller OEM metric exh pipes . I left in the rear cats , stock muffler & tail pipe. I did use all new lock nuts & Flange gaskets, All the o2 sensors are in place. All The heat shields were install. There is more to come . Just waiting on the Valve covers. and 2" x1" exh pipe band clamps
Cheers _PTEngineering
