ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Turn OFF traction control in 2013 ML63?
Old Dec 20, 2013 | 06:05 PM
Fantasm's Avatar
Car Whore
How do I disable traction control in a 2013 ML63?
I see the button on the console, but I think thats stability control only.
How do I get rid of the stupid *** traction control interfering with my driving?
Also, anyone notice how completely crappy the transmission is? It's always in the wrong gear and takes forever to DOWNSHIFT when I come up to a light or a stop sign and I need to start rolling again right after I come to an almost complete stop... it just sits there doing nothing -- its DANGEROUS.
Is there a TCU tune from any vendor to address this? Although I don't really feel the need to drop $1500~ to fix the ****ty programming from Benz on this car.
Old Dec 21, 2013 | 10:10 AM
EVOII_Racer's Avatar
Mercedes Evo II
The problem you are mentionning, when almost coming to a stop... IMO, just use your ride in m mode until you find a tuner that will fix the issue. When i upgraded my ECU it fixed the issue so it would be interesting to ask Nanook if Renntech also fixed this issue.
My tuner was able to fix the esp issue so in am sure you can find a solution with a good tuner.
Old Dec 21, 2013 | 02:33 PM
MercedesDad's Avatar
New, old Mercedes and REAL AMG's.
No way to completely turn the traction control off in the ML63, from the factory anyways. (Reason why the Cayenne Turbo scored better Than the Merc in the Fifth Gear comparison episode)
May have to go the aftermarket route.
Old Dec 21, 2013 | 03:03 PM
Mercedes Evo II
Dynomode is probably one way to do it but definitly not the safest way!
Old Dec 22, 2013 | 11:57 PM
Rippin'AV's Avatar
2008 ML63 AMG
But didn't the Mercedes engineers come in and secretly turn it off? There has to be a way...come on, somebody please leak that info! Knowing the Germans its probably a crazy set of buttons in a specific sequence. Do it wrong and the car will self-destruct
Old Dec 23, 2013 | 12:01 PM
You're right! They did.
It probably is a Top Secret designed to "protect the lives" of Benz drivers
That Cayenne drifting on all four wheels looked like lots of fun though!
Old Aug 29, 2014 | 10:40 PM
executive13's Avatar
2014 ML63
old post but no they didnt shut it off. It was still engaged. Even the engineers couldn't shut it completely off.
Old Aug 30, 2014 | 07:13 AM
schmick325's Avatar
RR Evoque Dynamic, Benz Valente (work hack)
Dyno mode cuts the power steering too, so not a good idea.
You're mixing 2 Fifth Gear episodes. The first one is with Tiff in the W164 ML63 and they say AMG turned it off but wouldnt say how. After that he's then doing effortless powerslides.
The W166 Vs Cayenne they could not turn it off at all. That and the seat belt tightening as the car thought it was going to crash all the time made it score badly.
Old Sep 2, 2014 | 09:38 PM
2014 ML63
No they did turn it off but it wasent off all the way. So it was partly off. That was with the w166. The w164 episode was NOT a comparison test. So yes they turned it off part way.
Old Oct 29, 2020 | 02:00 PM
jonnycs's Avatar
W166 ML63
It's a shame you can't turn it off. On my 2010 Jag XKR you just had to hold the down the traction control button for 14 seconds and then it just turned the displays red and left it up to you. Great fun but dangerous if you weren't carefull
