W163 Complete Differential Service Kit
Former Vendor of MBWorld
2012 SLS AMG
Click HERE to order or for more information.
Genuine Mercedes-Benz Differential Service Kit - $27.78*
In order to keep the front and rear differentials functioning properly, it is recommended that their fluid be changed every 50,000 miles.
ECS Tuning has made it easy to follow this service recommendation with this differential service kit.
This differential service kit will work for either the front or rear differential in your M-Class, but if you need to change the fluid in both differentials, you will need two kits.
This kit includes the following items:
One (1) Differential Drain Plug
One (1) Differential Fill Plug
One (1) Differential Drain Plug Seal
One (1) Differential Fill Plug Seal
Two (2) Liters of Mobil 1 75W-90 LS Synthetic Gear Oil
This kit includes all genuine Mercedes-Benz products, so when you change the fluid in your differential, you can do it with confidence knowing that you are using the same products that are used by the Mercedes-Benz technicians at the dealership.
*Price subject to change.
