ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Help w/airmatic suspension 07 ML63
Old Oct 22, 2015 | 10:27 PM
Tolltr0001's Avatar
ML63
I was getting the airmatic malfunction warning on my 07 ML63. Replaced the relay, didn't fix the problem. Replaced the compressor a couple days ago. Worked fine for a couple days. Now getting malfunction again and also had a warning the compressor was "cooling down". Pulled it back off after driving and it's not warm. Greased the electrical connections and reinstalled. The car isn't sagging but the compressor doesn't seem to be inflating the bags. Tried off road setting and raising the car but nothing happens. I also don't hear it purging like normal. Any suggestions would be greatly appreciated. I have no idea what the issue could be at this point.
Old Oct 23, 2015 | 12:00 AM
Rocman8's Avatar
E55
if it says its cooling down then it must be running constantly. there is probably a leak somewhere.
Old Oct 24, 2015 | 05:41 PM
vvrjrlaw's Avatar
1994 S420 RIP (2/8/13), 06 CLS55, 02 ML55, 94 TT Supra, 89 Maserati 228, 911 Porsche Carerra
I'd check for leaks because if the sensor is working properly it's saying the compressor is hot and is now calling down meaning it's running constantly. You've replaced the relay start checking for leaks. Good luck
