ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
code 9602
Old Aug 3, 2016 | 03:45 PM
markmassive's Avatar
2011 ml63
code 9602
Hello, just wondering if anyone knows what part to change with code 9602 Air Condition. so the symptom's of my 2011 ML63 is that when im using the AC it blows cold but after a while it blows hot air. what I do is turn off the climate control for a minute or so then turn it on again then it blow cold air. Please help im a newbie.
Old Aug 3, 2016 | 04:12 PM
2011 ml63
Originally Posted by Plutoe
You are low on refrigerant(you have a leak)---have someone put a set of AC gauges on the car and that will confirm----fix the leak and get on with your life!!
perfect thank you!!!
