ML63 AMG w164. Has a few issues. HELP!!
2007 Black ML 63 AMG
I have a ML63 AMG w164. Has a few issues.
Can anyone help?
Trouble Codes
1--ESP inoperable
2--Run flat indicator inoperable
3--Front fog lamp left
4--Auto light inoperable
5--Fuel level doesn't read correctly. When the fuel level reads half tank it's actually empty?? Currently it reads empty but it is actually full??
6--Right rear suspension sits a lot higher then the other corners?? Almost looks like the front driver side is leaking causing the opposite rear to sit high?
7--Should I invest in a MB STAR c5 tool? What is the difference between the c3-c5?
please help!:conf used:
Can anyone help?
Trouble Codes
1--ESP inoperable
1. Likely sensor in steering column or as simple as battery needs to be changed.
2. see 1.
3. still reading
4. still reading
5. still reading
6. I hate air suspension, always converted them coil over. Suncore has a kit.
http://manualmachine.com/mercedes-be...anual/page:62/
2. see 1.
3. still reading
4. still reading
5. still reading
Can anyone help?
Trouble Codes
1--ESP inoperable
Can anyone help?
Trouble Codes
1--ESP inoperable
