ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
ML55 trans,transfer case...
Old Apr 23, 2004 | 05:09 PM
arcaidy's Avatar
Was the only thing tweaked by AMG the engine or did they perform upgrades to the entire drive train? Were things like the transmission, CV joints and transfer case upgraded? What were they designed to handle? HP and torque levels is what I’m looking for.
James
I have an 01 ML55 if it matters any.
Old Jun 29, 2004 | 08:12 PM
autogunner's Avatar
The engine was the only thing, The transfer cases are all the same on all M classes and the trans. on all the V8's are the same. Autogunner. P.S. The exhaust,HCU,wheel speed sensors,frame,axles and O2sensors is also different but that is about it for the drive train.
Old Jun 30, 2004 | 12:34 AM
akbro93704's Avatar
2014 C250 sport
What is different about the frame?
Also, the transmission was AMG-modified:
Driver-adaptive electronic 5-speed automatic, AMG-modified for crisper, higher-rpm upshifts, with heavy-duty components and external liquid cooling
(www.mbusa.com)
The ride height was also reduced .3", and i have read that the shocks are stiffer, although MBUSA doesn't indicate it...
Last edited by akbro93704; Jun 30, 2004 at 12:37 AM. Reason: forgot to write something
Old Jun 30, 2004 | 03:02 PM
Y2KML55's Avatar
2000 AMG ML55
axle ratios are also different. shorter than the others at 3.73:1.
Old Jul 1, 2004 | 09:25 AM
autogunner's Avatar
On the ML55 and the ML400 The frame is stronger . Autogunner.
