Purge valve solenoid vacuum hose
I must be a terrible mechanic. I've worked on cars for years, but this one's got me stumped. I was throwing P0170 and P0173 OBD codes, so I and hooked up my smoker and found a vacuum leak, the purge valve solenoid vacuum hose at the back of my 2004 ML500 had come disconnected from the intake manifold. The hose is a thermoplastic formed type 12 l2124 with a slightly raised ring near the connection end. It routes under some random hoses and gets inserted into a rubber hose-connector which connects to the rear of the intake manifold.
There's just not enough room for me to fix this. I can't re-insert the the formed hose into the rubber connector. After hours of trying, I just can't do it. I can't get that rubber piece off of the back of the intake manifold either, but if I could, I would force it on the thermoplastic hose then hopefully slip that assembly on the manifold nipple, which (I dunno) may be barbed and maybe that's why I can't get it off.
If anyone out there has done this before, I'd really appreciate a suggestion.
