ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Lowered ML63
Old Sep 15, 2018 | 11:41 PM
LastLong's Avatar
2017 GLC43
Lowered ML63
Hi,
Whould like to know how do you lowered your ML63 ?
What I need to buy to lowred the vehicule? The Sport Mode is not lowered enough.
Thank you !
Old Sep 17, 2018 | 12:28 AM
eldos1's Avatar
06' W220 4MATIC (sold) 08'ml63 AMG
A few options:
1. Find someone with a Star system and have them reprogram the base height.
2. Lowering Links. You fool the ride height sensors by using adjustable sensor mounting brackets.
3. Lowering Module - Aftermarket "box" that takes in ride height sensor data in and adjust new offset signal data out. Can use remote to adjust on the fly the offset amount. Usually +/- 2" from the base setting.
4. Scrap Airmatic system for aftermarket struts/springs that are less than stock height or bag system.
Keep in mind that as ride height changes, the other alignment angles also change. Additional components to keep "geometry" correct maybe needed.
Old Sep 18, 2018 | 01:06 PM
LastLong's Avatar
2017 GLC43
Originally Posted by eldos1
A few options:
Thank you !!! I will check for someone with a Star system to reprogram the base height.
Old Oct 1, 2018 | 10:02 AM
LastLong's Avatar
2017 GLC43
A few options:
Weird... with a Snap-On System, we are able to lowering the car and it's perfect.... but when I start the car, the suspension goes back to its normal state....
Something we did not correctly?
Old Oct 1, 2018 | 09:37 PM
LastLong's Avatar
2017 GLC43
Do I need to using the Star Diagnostic System to lowering if I want to use only the Link Kit ?
Old Oct 9, 2018 | 12:49 PM
eldos1's Avatar
No. You will be physically be moving the sensor to a new height.
