Gear/sprocket puller for M156 heads?
New ML63 owner here, trying to fix the head bolt issue.
Can anyone point me in the right direction of where to buy the 24mm threaded adapter to pull the upper timing sprocket/gear shafts from the M156 heads?
Photo above from FCP’s blog. I called them to ask if they have, or know where to buy, and the fellow I spoke with didn’t know...
And, where the heck does one get new lower A.I.R. tube gaskets? I can’t seem to find those anywhere either...
I’ve been searching for days now for these two things. No luck. Hopefully someone here knows?
Thanks in advance.
