2003 ML55 - What is the plastic strip below each front headlight called?
What is the strip of plastic called under each headlight? Would any one be able to share a part number. I have searched a few OEM sites (Dealership sites) and cannot find them.
I found out how easy it is to break off the little plastic ends and need some new ones. Does anyone know what they are called or have a part number?
each is about 1 inch wide and 12 inches long. They slide / clip in.
After further research.... I had initially looked at the part and it had a faded piece of paper/label on it. Thinking this was the part number label I started searching.
After posting to the forum I saw a pic where a part number was stamped in the plastic. Aha! Went back and checked and yes, stamped in the plastic.
Hope this helps someone else.
Left = 163 826 01 77
https://www.mbdirectparts.com/oem-pa...16382601779999 = $36.91
Right = 163 826 02 77
https://www.mbdirectparts.com/oem-pa...16382602779999 = $41.14
