ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
2009/2010 tire size
Old Feb 23, 2021 | 09:26 PM
Try Me's Avatar
Mercedes E55 Amg
2009/2010 tire size
When you special ordered 21 inch rims on the 09 or 10 ML63 does anyone know what tire size was stock? Also should the tire size be the same all the way around, such as 295/40/21 on all four corners
Old Feb 24, 2021 | 12:51 PM
bensitto's Avatar
S550, R350, GL550, ML63 AMG
295/35 21 but you have the clearance for the 40 if you want to go thicker.
https://www.topspeed.com/cars/merced...y-ar66564.html
Old Mar 2, 2021 | 04:13 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
The facelift ML63 came with two wheel sizes.
Either the standard 295/40/R20
or
The optional 295/35/R21
And yes, tire size and tread pattern should be the same on all four tires on 4matic (AWD) vehicles.
Even if one tire has significant wear, this can damage the drivetrain and cause cruise control / ESP to have issues.
