ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
2011 ML63 Airmatic Fault
Old Mar 4, 2021 | 09:41 AM
aero summer's Avatar
2011 ML63 AMG
HI, i was towing 2 jetski's last weekend (about 2,000 pounds) and going around a corner the self leveling system turned on and tried to level the rear of the car by raising the height, I could feel the pump trying to lift the back of the car and then if finally quit after 2 or 3 tries and then did a reset I believe because the front left and then front right went up and down. An error then appearing that says Malfunction with an up error.
I didn't think much about it because I figured it was the ski's that caused th malfunction and it would disappear.
6 days later and the error is still there, the car rides fine, I don't notice anything wrong with ride height.
I tried to raise the car and 3 wheels raise to maximum hight but it appear the back drive side does not go to maximum level and an error appear that the pump needs to cool down.
What do you guys think?
Thanks,
M
