Windows and hatch operation different
thanks
Charles
With the window partly open, push and hold the window close button until the window closes plus three or four seconds. Release. Push and hold the window open button until the window fully opens plus three or four seconds. Repeat on each window, sunroof, etc.This procedure tells the DCM (Door Control Module) exactly where on the position sensor fully closed is, then exactly where fully open is.
Does your ML hatch use the gas-pressure struts to support/open the hatch? Or do you have the hydraulic system? If you have the hydraulic system, does the hatch also have the gas-pressure struts? If so, one or both struts may be too weak to help hold the weight. Rarely, the hydraulic system may be low on fluid.
