Hello everyone.. problem with driver door lock
Hello everyone i have a problem with my mercedes ml 2006 320cdi.. with driver door lock problem.. on that door.. i can only unlock the door.. but when i try to lock not work.. i teu to change mechanism lock i changed and nothing still not work.. i changed driver door module.. and same not work.. i check fuse , wiring.. all door lock , unlock but the driver i cam only unlock.. if i unlock/lock from diagnostic actuation test.. the door work .. lock and unlock but from key i can only unlock .. lock not work.. only another door work from key lock/unlock.. If you know a solution please.. im so stressed with that car i pay .. i do all only to solved... My whatsupp : +40771236911 I will sent you video to see exactly ..If contact me.. please Thank you so much in advice
UPDATE: The trunk not lock not unlock never..
And the interior light when i open the door not make on..
normaly when i close the door need to stop.. and when i open the door need to start the light on interior..
Please i pay and i make everything.. 👍🙏
Thank you
