Need advice
Ml350 4 matic
Need advice
I have a 2011 ml350 that started running rough (misfire). Used my OBD to get a code of P0301-P0306, all cylinders were misfiring, Swapped out all plugs and packs. ran better and got only a P0306 and P0351-P0356 low voltage/circuit. So i had a diagnostic on ECM and was told that Processor was bad. I put in an new ECM and i am continuing to get the P0306 and P0351-P0356.
I called the company that I bought the new ECM from and their best advice was to check fuses, Which I have done everything is good and has continuity.
Not sure where to go next.
Any help appreciated
